Cardboard Engineering using Sheet Metal Tool
john_doubledayjohn_doubleday Member Posts: 58 EDU
Has anyone used the Sheet Metal Tool to design for Cardboard Engineering?
  • awkawk Member, Onshape Employees, Developers Posts: 78
    Not really exactly what you're asking for (I think) but I have a (slow moving) project I've been working on at https://cad.onshape.com/documents/7a394ff491dd3c42917748fc/w/a46f338bc4dd0fa296f56692/e/7e02af042a02d302b9b27528
    The intention is to build an enclosure for the Creality Ender 3 printer - I prototyped it this weekend using some 1/8th inch foam board which has worked reasonably well - at least to show me the deficiencies before cutting any actual acrylic material.
    The enclosure is designed using in-context references (from Creality's open source STEP models) and surface extrudes, then constructing a sheet metal model to give me the flat pattern pieces that I can then nest and prep for simple plotting and cutting.
    (Unlike most of my colleagues I'm not a master CAD practitioner - others might have alternative proposals to achieving this :-)
    Director of API, Appstore, and App Partner Technical Support
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,944 PRO
    Yes, you can use sheet-metal tools for any material type that folds.
    You should adjust the bend radius and k factor to be much lower, because cardboard doesnt stretch, but rather collapses.
  • john_doubledayjohn_doubleday Member Posts: 58 EDU
    edited May 2019
    OK....thanks John. and AWK....this has huge potential for school projects....Flat Pack ....ANYTHING. I will investigate further.....Maybe the tool should be renamed....FOLDING MODEL
