Moving an assembly and multiple drawings that all reference the same part studio to a new document
edward_petrillo
Member Posts: 101 EDU
in General
I wish to move an assembly, the referenced parts studios, and the drawings for all of the contained parts from an original document to a new document. The steps described in an earlier discussion do not appear to offer a solution. When the drawing of part 1 is moved or copied, a copy of the referenced part studio is moved or copied as well. When part 2 (which references the same part studio as part 1) is moved, a second copy of the referenced part studio is moved as well. When an assembly containing these parts is moved or copied, an additional copy of the PS moves also. This process, if extended to all of the parts in an assembly, results in a new document with as many identical parts studios as there are drawings, plus one more. The new document is effectively useless for updating parts and drawings. Have I overlooked something? Is there a workflow that accomplishes the result I am looking for?
The most intuitively simple process would be to bring drawings as well as parts studios along when moving or copying an assembly to a new document.
1
The earlier discussion link in your post is dead, so it is not clear which functionality you are referring to. What you are describing sounds like Move to document. If you are careful planning the move, you should be able to get what you want. Using side panel select assembly and all drawing that you want to be moved, they would bring the part studios with them.
There will be no copies remaining in this workspace. This is indeed a move. If you can not achieve the behavior you are looking for, please share the document with support and publish link here with precise description of what you need to achieve. Some-one would help you.
