Multiple nested lofts
karl_davieskarl_davies Member Posts: 3
Drawing: https://cad.onshape.com/documents/c84be3eaa57835779958b51b/w/5ba0502032e859af3bbc6e36/e/7a26f09ac3996fbb3c7d839b
Nested lofts always seem to defeat me, is there any way to achieve the nesting below? So each ring should loft up to the matching, slightly smaller ring above it. I can sorta manage it by making each "wall" separately, then thickening by 1mm, but this means adding 19 lofts (inner one can render fine using the faces). Additionally, taking this approach, once the thicken is added there is a gap at the corners.
Many thanks!
