How do you "fill" a hollow space between two fill surfaces in complex geometry
the back corners ive left one side as far as i could get with extrudes and the other with the fill surfaces in place, however if i intend to 3d print, the surfaces leave a void in the slicing software so i need to fill them, im stumped, ive tried deleting faces, sketches wont work as everything is curved, i cant seem to make anything loft as there are so many vertices it breaks.
any ideas?
https://cad.onshape.com/documents/e981affacd226221d79d082c/w/eed7440417f10fe5eeea9fb2/e/75e64e8ed7c090334d947486
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
I would use a variation of the atomic fillet. Just create a big block that goes through that area. Delete those surfaces to create a surface model with easy to fill holes. Use fill or loft to close the holes, and Enclose to make a volume.5
Can you use the enclose feature?
https://cad.onshape.com/help/Content/enclose.htm
