Part/Assembly/Drawing/File Number tracking
Hi,
Is there a system in Onshape (professional subscription), where I can see what are assigned part (or assmebly, drawing, file) numbers already, so when assigning new part numbers I don't accidently same number?
Generally I use part number search engine to check what part numbers I have already alloctaed. But recently I have found that, this kind of search doesn't show parts that have configurations (thus thier 'part number property' varies) aren't being shown. Is there any workaround in Onshape that shows all the list of parts and only released items?
Thank you
Thank you
Have you tried Release Management?
https://cad.onshape.com/help/Content/release_management.htm
yes, I use release management and the part numbering system of Onshape.
However in our company, there is a change in one of the digits of part number for standard parts (and these are not revision managed), so they are differentiated from other manufactured parts. Hence, I manually assign part numbers to this category of parts. This is the reason why I am looking for any tracking tool on Onshape.
There does not seem to be a way to track part numbers including configurations
https://forum.onshape.com/discussion/10398/list-part-numbers-in-search-results#latest
Generally when you search using an identifier like <<P9*>>, in search using part number, the serach results in entities that has part number starting with P9. And when you click on the thumbnail, the details panel shows the part number of the part. I keep track of my part numbers in this way. However few days ago, I have found that parts with different configurations are not shown in this seach criteria. So, I went back to my old method of using excel sheet to keep track of parts.
Also in our company, we have different series of parts like P4 series, P6 series and the same with assemblies like A1, A2, etc. So, it will be great edition to Onshape tool if they could add something in search that shows all part numbers issued and which have been released and which are not.
