Sketch driven feature pattern in onshape
Hey, I'm looking for a way to repeat a feature in a non linear pattern. I would be able to make a sketch with points where i want the origin of my feature to repeat itself, I seem to remember that this is something that's doable in solidworks.
for example : see the screenshot here the fingers would have an irregular x repeat value
This isn't for repeating parts, really for features in the same part in a part studio.
Any help is appreciated !
1
https://cad.onshape.com/documents/9fca78cb66a0bc83e359eb3e/v/7b8e02af4e9b52af8d3ba60b/e/d7f44d3f530f6db8852edfeb#_ga=2.125751498.1132210461.1560810353-65381586.1560810353
https://cad.onshape.com/documents/9fca78cb66a0bc83e359eb3e/v/7b8e02af4e9b52af8d3ba60b/e/d7f44d3f530f6db8852edfeb#_ga=2.193400366.246606404.1560247454-1626774034.1560247454
(just kidding, they are all awesome
That said, mine is the best because its (a) parametric (all points in a sketch even if edited later) and (b) you can select seed parts from other part studios and other documents!
https://cad.onshape.com/documents/e02f8da5c872d4d55e30e218/w/41d8b64176967ea1955c14fa/e/aff7ca3a7b06f2e095750678
If you are, like the OP, looking to pattern Features based on Sketch Points, check: https://cad.onshape.com/documents/9fca78cb66a0bc83e359eb3e/w/01ed403357f48b8904c9b631/e/268a22f0ce6b3864a3637732
Earlier (2019) answers link to Feature Scripts patterning Parts.
