2 points with tangent arc
darren_mason871darren_mason871 Member Posts: 44 ✭✭
I am trying to connect 2 points using the tangent arc. I tapped pencil/tangent arc/precision selector/dragged across the 2 points, and nothing is happening. What should I do?
    Tangent arc needs the end of a line as a starting point. Try 3 point arc instead. I recommend reviewing the training videos at learn.onshape.com (although these do not cover the mobile version, the concepts are the same).
