cannot add sketch fillet
darren_mason871darren_mason871 Member Posts: 44 ✭✭
I made this L shape out of lines. Then I selected a plane, tapped pencil, tapped sketch fillet, tapped a corner, and I got the error: cannot add sketch fillet. What do I need to do different?
    edited June 2019
    Hi,
    First guess is you have a small part and the default fillet size is too large to regenerate.
    If you post a link to the doc someone will be able to take a real look rather than taking a guess ;)
    Cheers, Owen S.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    The sketch fillet is failing because it defaults to 5mm in size. If your lines are shorter than that it will fail. On desktop you can click and drag a fillet to size. Embarrassingly, I can’t work out how to do it on mobile so I will ask someone who does. In the meantime, can you make your lines temporarily longer in order to add the fillet? You should also consider adding your fillet as a model feature after the sketch has been extruded. As a rule of thumb, only add fillets to a sketch if it is a functional requirement- if it’s just to break a sharp edge, add it as a model feature.
  • lanalana Onshape Employees Posts: 746 image
    The description sounds as you are trying to add a sketch fillet in a sketch feature different from the one in which lines were sketched. It would only worked for the lines sketched in the same sketch.
