Extruding the rim for the wheel lesson
a_kadisha_kadish Member Posts: 4
I'm on step 19 of the wheel rim project. I can't get the extrude to cut
the wheel rim out. What am I doing wrong? I have everything correct
according to the demo. The only thing I can think of is that the inner most
selection from which the extrude is starting from has the triangular cut
out and that is not allowing the system to generate a path. If that is the
problem, I am unable to select the inside area. If that is the problem,
where did I go wrong at the outset, since everything looked exactly as in
the demos. Thanks
