Imported Image is Black
famadorian
Member Posts: 390 ✭✭✭
For some weird reason, when I import this image, it's black.
I've also tried to convert it to JPG, but it's still black;)
What's going on? Onshape loads my other images.
sebastian_glanzner
Member, Developers Posts: 483 PRO
I suspect the Resolution of the image is very high. Try to reduce the number of pixels and upload it again.
This solved a similar problem I had.1
https://drive.google.com/open?id=1dDz-W5vltcDTWwWcnHP5zIKypFVJ-PFt
I need help;)
Go open up that document again. I brought that image into a Part Studio.
The image is washed out looking. But it’s there.
You see it here?:
https://cad.onshape.com/documents/9d3bffcd728fbb12a7fed853/v/f3dddb224d96f57afdf1c9aa/e/b075371710343ff96d8a1c1d
OK the below two images are screen captures I made of what I’m seeing.
Look at the name of the document. This is the copy you made
I’m using an iPhone 8+ and I’m obviously using the mobile app for the iPhone
Looks to me like it’s something to do with your graphics card on your computer or your browser
PART STUDIO —
IMAGE —
Can you try on a computer?
It is showing for me in your document while using Chrome and a MacBook Pro.
I would consider shrinking the image resolution down some if you are going to be compressing it so much in a sketch anyways.
It is black to me on mobile version of chrome
It works on mobile version of firefox
i'll check on my pc when i get to work.
GPU:
Extra note: It works with both the integrated intel graphics card and nVidia card
1. Can you send us the output of chrome://gpu ?
2. Can you check if any errors are being reported in the browser console. This can be opened using the following shortcut keys :
(Linux/Windows) Control+Shift+J
Yup, scaled it down and works perfectly;) Thanks
So, this is a bug, then, but only with me, it seems.
Do we have a bug tracker?
We don't have a bug for this. Can you please create one for support via the help menu? This way you can get notified, when it does get addressed.
Thank you.
Paul
