3D Fit Spline touch and drag
darren_mason871darren_mason871 Member Posts: 44 ✭✭
I read online that I can tap a line and then touch and drag to adjust the start and end direction.  I've been using android and I've tapped a line making a 3D Fit Spline, and the ability to touch and drag the line isn't happening. How do u do that?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    Drag is only for sketch - edit the fit spline to change the end point
