Imported Image is Black
For some weird reason, when I import this image, it's black.
I've also tried to convert it to JPG, but it's still black;)
What's going on? Onshape loads my other images.
  • sebastian_glanzner
    I suspect the Resolution of the image is very high. Try to reduce the number of pixels and upload it again.
    This solved a similar problem I had.
  • famadorian
    famadorian ✭✭✭
    I can't even attach the file here in the comments;)
  • famadorian
    famadorian ✭✭✭
    Even after I convert the file to Gif, it turns black;)
    I need help;)
  • famadorian
    famadorian ✭✭✭
    I made a copy of your Onshape document, then I made a part studio and put the image on a plane and it's still black
  • steve_shubin
    steve_shubin ✭✭✭✭
    @famadorian
    Go open up that document again. I brought that image into a Part Studio.
    The image is washed out looking. But it’s there.
  • steve_shubin
    steve_shubin ✭✭✭✭
    @famadorian
    OK the below two images are screen captures I made of what I’m seeing.
    Look at the name of the document. This is the copy you made
    I’m using an iPhone 8+ and I’m obviously using the mobile app for the iPhone
    Looks to me like it’s something to do with your graphics card on your computer or your browser
    PART STUDIO —
    IMAGE —
  • famadorian
    famadorian ✭✭✭
    I loaded this document into my android and there is nothing there, either.
    Can you try on a computer?
  • Per chance, are you using Firefox?
    It is showing for me in your document while using Chrome and a MacBook Pro.
    I would consider shrinking the image resolution down some if you are going to be compressing it so much in a sketch anyways.
    Jake Ramsley
  • Works on iOS.
  • Works on Chrome + Windows 10 + Lenovo Thinkpad P52s :)
  • Works in Onshape app on Samsung note8
    It is black to me on mobile version of chrome
    It works on mobile version of firefox
    i'll check on my pc when i get to work.
  • famadorian
    famadorian ✭✭✭
    ok, this is too weird. Some images are totally fine, but some are not.
  • famadorian
    famadorian ✭✭✭
    I'm on Ubuntu-18.10 GNU/Linux with Chrome
    GPU:
    03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Vega 10 XT [Radeon RX Vega 64] (rev c1)
  • famadorian
    famadorian ✭✭✭
    you can see in the preview that it loads the images;)
  • works in chrome and firefox on my windows10 laptop, It is slow to load though, it is blank until it is fully loaded.
    Extra note: It works with both the integrated intel graphics card and nVidia card
  • Paul_J_Premakumar
    edited June 2019
    The preview is a png file that is displayed by the browser. The image in the modeling area is a texture that needs to be applied to a quad. This looks like an issue with the GPU/browser.
    1. Can you send us the output of chrome://gpu ?
    2. Can you check if any errors are being reported in the browser console. This can be opened using the following shortcut keys :
     (Linux/Windows) Control+Shift+J
  • famadorian
    famadorian ✭✭✭
    Yup, scaled it down and works perfectly;) Thanks
    So, this is a bug, then, but only with me, it seems.
    Do we have a bug tracker?
  • famadorian
    famadorian ✭✭✭
    https://pastebin.com/UfespkbT
  • @famadorian,
    We don't have a bug for this. Can you please create one for support via the help menu? This way you can get notified, when it does get addressed.
    Thank you.
    Paul
  • Thank you so much for the indeed, incredible concept to share with. I do admire the effort and will continue to learn from these forums.
