How Do You Widen Text in a Sketch?
I've been pouring over these forums, and I can't quite find my answer. I need to widen the text of a part in one direction (horizontally). Is there a one-direction scale feature? Why doesn't Onshape have a scale feature in its sketches? I'm a bit of a CAD newbie, so any help is appreciated.
Among other options, it features the ability to add horizontal spacing to text ( IE, Height and spaced width are independently configurable.
You can read more here:
http://store.parametricparts.com/store/p10/CURVED-TEXT-1.0
or simply load up the document directly, here:
https://cad.onshape.com/documents/cfec40e2b66bb4ddb2f3414b/w/24132f252a02825eb0606641/e/7a70ac021729253c4df9d213
However, a quicker way is to 'Fix' the text box corner in place instead of using dimensions.
I think that the best way to achieve what you are looking for is to first make the sketch and commit it. Then use "offset surface" (with offset set to 0) to copy the sketch as a bunch of independent surfaces. Then, use "transform" to do a nonuniform scaling of those sketch letters. (you'll probably want to use 1 as the scale factor for the two dimensions that are not stretching, and something larger, maybe 1.1, for the dimension that you want to stretch). Definitely a workaround, but it should get you what you want.
https://cad.onshape.com/help/Content/offset_surface.htm
https://cad.onshape.com/help/Content/transform.htm
