possibly a selection problem
darren_mason871darren_mason871 Member Posts: 44 ✭✭
On this 2 plane file I keep getting errors when trying to use the pipe custom feature. I also couldn't use the fillet tool or the 3D fillet custom feature. I've selected the plane I was working on. What am I missing?
https://cad.onshape.com/documents/1bf91551f50c911edd129814/w/a67780b926bd88be521bd95a/e/d081f73e4b4ecfcdddddfcf6
  • steve_shubinsteve_shubin Member Posts: 1,111 ✭✭✭✭
    @darren_mason871
    There’s a gap between the lines of your two sketches.
    The USE TOOL allows you to join one sketch to another. So the idea is — while in Sketch 2, use the USE TOOL to locate the end of the line in Sketch 1 — you have already done this - you already have that point in Sketch 2.
    And then while still in Sketch 2, draw your lines so that the horizontal line is attached to that point you made with that USE TOOL. You need to do this part in Sketch 2 because you drew the lines in Sketch 4 which is the wrong sketch. To EDIT Sketch 2 in order to make these changes, tap the vertical ellipsis to the right of the sketch name in the features list, and then select EDIT
    Sketch 3 is a duplicate of Sketch 2, so delete Sketch 3
    Delete Sketch 4
    Also, in Sketch 1, the line that looks horizontal is actually not horizontal. So you may want to apply a horizontal constraint to that.
    I made all the lines longer. You had everything pretty small and that might be why your Pipe Tool wasn’t working
    I made the changes above and I applied the Pipe Tool. You could see it all in the document below
    https://cad.onshape.com/documents/e1bcff8e1baf243dc4533dd2/w/9cc5842314ebad0d605f8343/e/aab99ba1a4ad8e98369fd40a
