How do i use sweep or revolve on a spline?
mateo_andrademateo_andrade Member Posts: 1
I have drawn a spline and i am trying to turn it into a tube. it will not let me turn the spline into a tube. whenever i try to revolve it wont let me draw the lines in order to do it. and when i want to sweep it just goes red.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Presumably the spline is the tube centreline? Revolve will only work with a straight line axis. If you are sweeping a circle along the spline and it is red then it is self-intersecting - try a smaller diameter circle.
    ...unless you did not create a plane 'normal' to the end of the spline with a shape (circle?) that can then be be swept...
