SolidWorks --> SWOOD
in General
SolidWorks has (in some way) incorporated "booster" named SWOOD. It is "made" for use in cabinetry, woodworking.
Is there any similar solution in Onshape (dowel holes spacing, depth, diameter, hinges holes, cutting plans, material lists, calculating panel dimensions regarding on edgeband thickness, ...)
Looking forward for your answer
Best regards
Zvone
Best regards
Zvone
Beams (for timber frames): https://cad.onshape.com/documents/e15c2c668d138f01242d0c80/w/0664d65a957c7bfba7cfbddd/e/bd6831589391741e327fec75
Box joint: https://cad.onshape.com/documents/57612867e4b018f59e4d52ce/w/1e657f13b93a753115dcbd12/e/29340b9ea8177088647ffe75
Lap joint: https://cad.onshape.com/documents/578ce95de4b0e425c1f00cda/w/cbc0b1ab48f411a4675afae1/e/6dbd408b8dc213a84767ec69
T-slot joint: https://cad.onshape.com/documents/5791a167e4b03c2aa6af3b35/v/59c55ebbb7f52936dae70676/e/acc455ae2adcf11a571ba510
Laser joint: https://cad.onshape.com/documents/578830e4e4b0e65410f9c34e/w/d04a088a0a8ab8361a2aa65c/e/7af109b2f1cead90850525ae
Butt joint with pin: https://cad.onshape.com/documents/deaa950158a21eba4f7b2cda/w/2bfb98be5224679ffce1a954/e/8e76e625e7b88102e7c7cb65
To add one of these custom features to your toolbar simply click the [+] Custom features button:
Onshape, Inc.
