Can I get a 3D model of the flat Sheet metal?
quincy_payne
Member Posts: 2 ✭
I am looking to make a quick part of 3d printed TPU and would need to edit a flat model of a sheet metal design. Is there a way to get the flat model of the sheet metal into a part studio to then continue editing?
john_mcclary
Member, Developers Posts: 4,059 PRO
Sure can,
There are a couple ways you can do it. The one you may want to try first will also return the result back into the bent model.
Open the sheet-metal tab and create a sketch on the part face, then extrude add/remove.
If you want it to be a new part. then you can extract the flat pattern without the bend lines (more laser table friendly) by using this feature script
https://cad.onshape.com/documents/d075777b23239493791a6871/v/3a17d545652276fcd92ed873/e/dba9566c2dda32a29752e76b?showReturnToWorkspaceLink=true
5
-Quincy
Would this be possible?
