Is There a Method That Will Mirror a New Part With a New Appearance/Color?
larry_hawes
Member Posts: 478 PRO
Thought it was user error but when mirroring a new part the appearance stays the same as if it were 'added' instead of 'new'. Changing the appearance of the original part changes both due to, I assume, the mirror operation.
Changing the appearance of the 'new' mirrored child part does indeed change the appearance but it's an added step and inconsistent with OS's normal 'new' part behavior where each new part has a different appearance attribute.
Thanks
http://www.youtube.com/watch?v=N2lt9IO2fdU
Thanks
http://www.youtube.com/watch?v=N2lt9IO2fdU0
FIXED
Onshape has a predetermined color palette and rotation of color assignments as parts are created. (You are also able to assign custom colors to parts, explained below.)
As parts are created, they are rendered in a sequence of eight colors, shown below, from left to right, with the sequence starting over on the 9th part:
An option would be good but if others don't care then I'll learn to live with it as it's a pretty small issue.
Can't really see how to have it both ways...
