FS sort by keyword on mobile
steve_shubinsteve_shubin Member Posts: 1,113 ✭✭✭✭
edited July 2019 in Product Feedback
I entered the below under an improvement request. I don’t know how to point anyone to it because it just seems to have disappeared into the ether.
Anyway, below is what I entered in the improvement request area
The below is with regard to Onshape on the iPhone.
This is about how FeatureScripts are placed in random order. If there is a way to change the order - I’d sure like to know, because with almost 100, sometimes it takes me awhile to find the tool that I need.
It would certainly help if I could sort FeatureScripts by keyword. I would like this at the account level so that the sort stays when changing from document to document. And I would like the sort to hold when I turn the program off.
For keyword sorting, there could be a list (of all FeatureScripts) where I’m able to add keywords to these FeatureScripts.
All FeatureScript’s that have a keyword would be numerically/alphabetically ordered (by keyword) at the top of the list. Those FeatureScripts without a keyword would follow - at the bottom of the list.
The sort should happen automatically once you apply a keyword.
This way, If you work primarily with 20 different FeaturesScripts, you could have them right at the top of the list.
While using the Onshape iPhone app, I don’t want to search for a particular FeatureScript by keyword. That is, I don’t want to type in a keyword to search for and then select and use a particular tool (FeatureScript). I only need the keyword to help me sort the FeatureScripts — i.e. to put the FeatureScripts in a particular order under the Features icon (the globe)
The GIF below shows the random order of the FeatureScripts
    @steve_shubin
    Your improvement request is under review and will be processed shortly.  Thank you for bringing this to our attention.
  • steve_shubinsteve_shubin Member Posts: 1,113 ✭✭✭✭
    A truncated example of the ‘list for adding keywords’
    It would be nice to group all the Plane tools or Wood tools together
