No results from Performance check
Henk_de_Vlaam
Member, Developers Posts: 265 ✭✭✭
I gave myself a present: a DELL G7 7790 with a NVIDIA GeForce RTX 2060 graphic adapter to get Onshape on high speed. After starting Onshape I was curious about the speed and ran the System Check. The result is below:
I checked the refresh rate with www.testufo.com; that gave 60 Hz.
Can anybody help me to get performance results out of the System check?
Henk de Vlaam
john_mcclary
Member, Developers Posts: 4,028 PRO
My laptop did that to me the other day, although I had Solidworks running a large assembly and 3 Onshape projects open. Computer was at max capacity most of the day.
It came back after I closed Solidworks though, and everything is ported to 2 1080p monitors through a cheap usb3 docking port... soo, hard to nail it down.
I assume you went through the "close all background apps, and reboot" scenario already yes?
I assume you have it plugged into your power pack? These laptops will severely reduce processor/GPU performance in favor of battery life when unplugged.
Lastly, if it is a new PC, it takes a week of use before all of the drivers and program settings are content, so the whole system seems dog slow at first. Once all the background downloads and updates are done, the system can cashe resources better and everything speeds back up.5
[1] I really don't know whether this is interesting or not but it might be useful.
I also get the message "Potential browser stutter occured (1)".
@john_mcclary,
I did the test with a bare laptop. So, no other apps did run and the power pack was connected. When I look at Windows updates I see some updates with status: waiting for download.
So I'll wait some days and do the test again. Then I'll be back with you.
I went and tried again after a few weeks now it does 90 fps no problem.
@john_mcclary,
The results arrived after a week of patience.
Yes and no.
This afternoon I saw the very satisfying results
Your GPU will give scale performance differently with full screen / full screen windowed / and windows mode also. So it would make sense that you will get different results based on window state.
I do believe even the cable connections can make a difference.
For example: if you use a DisplayPort -> DVI adapter it will not be as good as a DisplayPort -> DVI Cable.
Notes on multi-monitor:
- if you open and run a program on the "Main" monitor (You can tell it is the main monitor if you have the notification panel and background apps by the clock in windows) it will get significantly more GPU power than your secondary monitor. (This is for all apps, even excel and outlook etc.)
- if you are feeding your video output through a docking station, the quality of the dock and what port you use can have a massive impact as well. (In my case I have the worst of both worlds above on my work setup. I need to unplug the docking station, open chrome, log into Onshape, then I can plug my docking station back in. Otherwise it uses the Intel chip and is noticeably slow.) This does not happen with all docks, the guy behind me has a cheap monitor (usb->2x HDMI) feeding (2) 2k monitors, and it will allow the correct GPU to run chrome every time.
So, basically the 2LDR is : you will need to troubleshoot your unique set-up, one piece at a time
Now when I check the performance, it will be around 830 mill and 630 mil even with the station plugged in.
