Featurescript - Evaluate centre of circle
Hugh_GoodbodyHugh_Goodbody Member Posts: 41 PRO
I am embarking on my first custom feature creation! I have run into an issue someone might be able to shed some light on.
I have selected the edge of a circle and would like to get the centre point to place a hole on. I have the below code to evaluate the selected circle:
var circleCentre = evCurveDefinition(context, { "edge" : definition.startVertex });
        println(circleCentre);
        var myVar = circleCentre is map;
        println(myVar);
        println(circleCentre.radius);
        println(circleCentre.center);
The first two println ststements give the expected results:
println(myVar) = radius 0.024999999999999994 meter
                          center (-0.10832993533461188 meter, -0.025 meter, 0.08940204711347347 meter)
println(circleCentre.radius) = 0.024999999999999994 meter
However, the last statement returns undefined, but I was expecting the coordinates.
println(circleCentre.center) = undefined
    you can use evCurveDefinition(context, { "edge" : definition.startVertex })<strong>.coordSystem</strong> to get the coordinate system of the circle. You can use evCurveDefinition(context, { "edge" : definition.startVertex })<strong>.coordSystem.origin</strong> to get the center of the circle
  • Hugh_GoodbodyHugh_Goodbody Member Posts: 41 PRO
    Splendid, thanks for the advice. Will give it a go.
