Опция "скопировать в буфер обмена". Option "copy to clipboard"
Уважаемые гуру! В контекстном меню Part Studio есть опция "скопировать в буфер обмена". Не могу понять, как пользоваться. Помогите!
Dear Gurus! In the context menu of Part Studio there is an option "copy to clipboard". I can’t understand how to use it. Help!
NeilCooke Moderator, Onshape Employees Posts: 5,868
Go to the + menu (bottom left) and select Paste tab (in the same document or a different document)Senior Director, Technical Services, EMEA5 -
bruce_williams Member, Developers Posts: 842 EDU
Right click folder and 'unpack'. That moves contents to parent and deletes folder. It is a little esoteric even for us english speakers!www.accuratepattern.com5 -
Select “unpack” - this deletes the folder but moves the contents to the level above.Senior Director, Technical Services, EMEA5 -
MBartlett21 Member, OS Professional, Developers Posts: 2,057 ✭✭✭✭✭
You can select the constraint and press Delete or Backspace on the computer5
