Cannot extrude up to face problem
omri_romri_r Member Posts: 10
Hi!
Would really appreciate if someone can help.
I'm trying to extrude a sketch up to two curved surfaces in and than remove the surfaces to end up with cylinder like shape.
From some reason I get an error while extruding but I cannot figure why.
Any ideas?
Thanks a lot!
https://cad.onshape.com/documents/5fa5d6d098f26e7ce7bfee26/w/74a18b94219b5963711e9f95/e/c95cfbfa5237491231f054e2
  • steve_shubinsteve_shubin Member Posts: 1,113 ✭✭✭✭
    edited August 2019
    @omri_r
    1. Make Part 1 and Surface 2 invisible
    2. Extrude to face of Surface 1
    With the Extrude Window still open ——
        3. Make Surface 1 invisible
        4. Make Surface 2 visible
        5. Turn on Second end position
        6. Set it to extrude to face of Surface 2
    edited August 2019
    @omri_r
    The post above now reflects what is shown in the two GIF’s below
    edited August 2019
    @omri_r
    Here is another GIF where I hid Part 1 before using Extrude
