I want to make a helmet shape and have tried to use a loft
Hi all,
Any ideas?
Thanks
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@peter_clifford
It seems like that curve you have sketched should be used a guide, not a path. As Bruce says, it will be easier to see what's going on if you post the link to your document.Jake Rosenfeld - Modeling Team6 -
mlaflecheCAD Member, Onshape Employees, Developers Posts: 191
@peter_clifford Perhaps using Normal to Profile and the Path with 5 sections is causing a conflict. Also, creating a surface with a thicken operation afterwards is way easier than trying to loft complicated sketches.
This type of geometry may be best served by using several surface models put together. My colleague @jdesilets created this awesome helmet design from a couple images natively in Onshape. Take a peek: https://cad.onshape.com/documents/22aec34a5bba7a6a8a12ce08/w/db3487a329c1d1bf00b4f7da/e/6fe7e59de9ea2c65983675d5Regards,Mike LaFleche @mlaflecheCAD5 -
bruce_williams Member, Developers Posts: 842 EDU
changed the end points of Sketch 3 to be pierce constraints and it works...
https://cad.onshape.com/documents/48bfd34949ae981c51237393/w/66c5241fd9da8d2e08391529/e/61e82940bf70d1ec509348de
www.accuratepattern.com6 -
philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
Philip Thomas - Onshape6 -
billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,114 PRO
Tell Johnny D that he did a really nice job.
It's very organized, which makes it a joy to scan through looking to see how it was constructed.
Thanks for posting.
5
please post a link to your document; see these guidelines:
https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
(Not mine - Johnny D's
Thanks for posting.
