  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
    Did you delete the doc? Resource does not exist.
    The doc must also be public for us to look at it.
  • sumran_shahidsumran_shahid Member Posts: 6 EDU
    edited August 2019
    My Doc is still here visible to the community (forum) only.
    edited August 2019
    Go to the share dialog and make your document Public.
    edited August 2019
    OK
    Done
    NeilCooke said:
    They all look fully defined to me? All sketch entities are black.
    There's only the end of the centerline in the first sketch that can be moved.
    Thanks for answering, Sir.
