Mass Exporting Step and Drawing Files
michael_bromley
Member Posts: 110 PRO
I have not done any work with featurescripts yet, but I'm hoping to explore this as an option. I'm mainly looking for feedback on whether or not what I am after is possible through feature scripts.
Outsourcing fabrication work requires that we export a step file and a pdf drawing for each part to be made. Currently this requires me to dig through the document, locate each part, export and save as the part number + revision and then rinse/repeat with the drawings. As you can imagine this is a cumbersome and lengthy process.
Would it be possible to write a feature script to automate this process? Essentially I need a way to select a bunch of parts and drawings and then export in some standardized naming convention that is a derivative of the part number and revision.
7
I currently have a Bubble app that exports all drawings in the document
@MBartlett21 do you have more info on your app?
My app was working until a few releases ago, when it stopped exporting drawings
There needs to be a way to change the default export naming to PART#_REVISION_DESCRIPTION or similar.
Batch exporting is also desperately needed. I'm literally spending multiple full days just exporting drawings.
For batch export with specific naming, I would recommend our API for the time being.
We do have significant request volme for both of the requests you are making. Please add your vote as well:
Here is an IR for batch export:
https://forum.onshape.com/discussion/6947/batch-export-files
Here is an IR for changing the default name of an exported file:
https://forum.onshape.com/discussion/4753/export-parts-with-pn-and-revision-number-included-in-the-file-name/p1
