Multiple copy of part on designated location.
francois_carlettofrancois_carletto Member Posts: 5 ✭✭
Hi expert team.
Creating a part,for example a table foot, i want to copy this part in 6 designated location (for 6 feet under the table). I created 6 point on a draft and want to copy the foot part to this 6 point. I can use the transform, coping with mate connector but that only create 1 copy of the part. I need so to redo this action for all the 6 feet.
Is there any way to do a kind of pattern with as option copy part in affected location (selecting the points of the sketch as designated location)?.
Thanks
    @francois_carletto
    The "New" "Add" "Remove" "Intersect" options should exist on that feature, at the top of the dialog, and do what you are asking.  Are they not working for you?
  • francois_carlettofrancois_carletto Member Posts: 5 ✭✭
    Sorry. Error from my side. Thanks a lot for that return.
    Thanks so sir for this specific feature that correspond to my need. I understand the interest for creating that in assembly but it stay very usefull.
    The next step is to integer the merge option (add / new / remove) in it even if we can use Boolean operation to do it for yet.
    @francois_carletto
