Reference configured features in configured part properties and/or parametric drawing notes?
Malcolm_Daniel
Member Posts: 57 PRO
Any tricks for referencing configured features in configured part properties and/or parametric drawing notes?
Looking to parametrically reference the "Substrate Stock PN" below (configured feature) in a drawing note. Only way I can think of is copy/paste that column into a configured part property column...but then it's not parametric i.e. if I change "Substrate Stock PN", it wouldn't update the configured part property.
Thanks,
Malcolm
Thanks,
Malcolm
OptionsMalcolm_Daniel Member Posts: 57 PROHere's the Improvement Request: https://forum.onshape.com/discussion/12191/insert-configured-features-columns-into-notes-callouts1
Yes, it's totally doable
Here is a link to the document so that you can see how it's done.
https://cad.onshape.com/documents/6d7599c90a79cea411afb675/w/9cfbdb054821e4b14728f010/e/eea77f4cd9b3f7977bf5fcd7
1) There exist configuration specific properties
2) Insert multiple configurations of the part into the drawing
At this point, there are three views (each of a different configuration) - BUT THE SHEET REFERENCE IS ONLY TO THE CONFIGURATION OF THE FIRST PART INSERTED.
This is the head scratcher - each sheet can only have 1 reference regardless of the number of different parts/assemblies/configurations referenced.
Inserting a note referencing a custom property will only insert the value of that property for the sheet-reference (not what you were looking for)
3) The correct way is use the Callout (balloon) tool as this points to a specific view (and hence configuration)
I hope this helps you
What I'm trying to do is parametrically link the note to the configured FEATURE (not configured PROPERTY). As I mentioned, I can copy/paste configured FEATURES to configured PROPERTIES (via spreadsheet in-between) for use in parametric notes or balloons...but then when I change the configured FEATURE I have to manually update the configured PROPERTY.
Got any other tricks up your sleeve for that one?
We are trying to understand what you're trying to do.
In the absence of a document to look at, we are trying to figure out what "Substrate Stock PN" is? It appears to be some sort of configuration parameter. How is it defined? Is it a variable? Why is there an arrow to 'configured part properties'?
The most helpful would be a public document with your problem reduced to its simplest representation
Check out the notes on the two drawing tabs. Let me know if you need more info.
In this example, the "Derived 1 Configuration" column/field/name in the "Finished Part" part studio is analogous to "Substrate Stock PN" in my real-world example. Arrow to Configured Properties in original post indicates I want to be able to parametrically reference that configured feature (value of that column) in both Configured Properties and drawing notes.
Another way of thinking of this is a "make from" item (take stock part XYZ and modify it).
https://cad.onshape.com/documents/597c26021f533f1cb381dc50/w/1715d3554997e096ec56961a/e/71b9841cbc8ac2553c57ac53
I used the exact method described above
https://cad.onshape.com/documents/5d5994909ce52f225aefed6a/w/6460e07babc439363f1d9fab/e/0b39f7b6ebe746215d83e0c1
There is no mechanism for those cells to read the values from somewhere else.
