Auto-Made date on 2D is Wrong
Mazie_HouchensMazie_Houchens Member Posts: 36 ✭✭
edited August 2019 in Community Support
Hello!
I just realized that when I create drawings, the auto fill section is putting in dates from March (03/19). Is there a setting I can change to fix this so its more correct?
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    This might be based on server time. Where in the world are you signing into Onshape?  You can also submit a bug to us and we can look
  • Mazie_HouchensMazie_Houchens Member Posts: 36 ✭✭
    Okay thank you! I'm in the Oregon Coastal region so not anywhere way out of the way. I'll probably submit something before my next project I appreciate the help!
