Can't select anything but the origin in sketch
damon_rowan
Member Posts: 4 ✭
in General
Hi, I am new to Onshape, I have Solidworks experience but it has been a few years since I have worked with it. I think I have forgotten more than I seem to remember. I am making a very simple ball socket but can't create a profile for the Helix because I can't seem to select anything except the Origin when any sketch tool is selected. I can select everything just fine when I don't have a sketch tool selected. I know it is probably something simple I am forgetting but can't figure out what it is. Any help in the right direction would be greatly appreciated. The part is public and called "Socket test"
https://cad.onshape.com/documents/887c70703e22b477d68872fe/w/517735809fc2749884183e3a/e/8526746f01370a685e11475a
You have a few options here. You either need to bring the geometry of the part in question into the sketch using Use or Intersect:
https://cad.onshape.com/help/Content/sketch-tools-use.htm
https://cad.onshape.com/help/Content/sketch-tools-intersection.htm
Another thing you could do is just sketch the curve you want, and then use a constraint to constrain it to external geometry without bringing that geometry into the sketch. Constraints are the tools all the way on the right of the sketch toolbar, like Tangent, Pierce, and Coincident.
https://learn.onshape.com/courses/fundamentals-sketching
