How to deform a solid
alain_carrot768alain_carrot768 Member Posts: 3
edited September 2019 in Community Support
Hello !
I try to deform the entire object so that its base fits an arm or a leg.
https://cad.onshape.com/documents/57e2bc52ee8b8e2ad02ce345/w/9942a0734ef530a5126f6a7e/e/0dfe7a683ffeefd06984736a
But I don't succeed with wrap or metal functions ...
I really don't know how to proceed.
Could you help me ?
Thanks you !
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,414
    Hi - what do you want to deform it with? If you have a scan of the arm or leg, you should import the mesh and model around that.
    Hi thanks for your answer.
    Without even using a specific model of leg or arm, I do not succeed to twist the object so that it can fit with a single cylinder.
    Thank you for your help.
    It can't be done - it should be modeled in the final shape.
