How to combine imported assemblies into single line item in flattened BOM
rob_rowland
                    Member Posts: 19 ✭✭
                                  in General
                    For example if I import a ball bearing assembly, which might have 20 bodies (inner race, outer race, balls, cage, shields, etc.), it is showing up at 20 unique parts when I view it in a flattened BOM when it comes time to order components.
This makes the BOM very difficult to use if you aren't the person who designed it. I then have to copy the BOM to a spreadsheet, and manually fix all the instances where this occurs, which means I ultimately spend more time dealing with BOMs than if I had just used Solidworks.
How can this be fixed? Is there a way to merge multibody parts to show as a single part (not an assembly) within Onshape?
Or you can boolean union everything to a single body.
https://cad.onshape.com/documents/7efdc46d39f48a6d386664fe/w/99b774b13038e42938514e07/e/fb6aac82cf121235a083e37e
The draw back is that a decision has to be made about which style to use at the out set as to whether you'll use a structured or flattened BOM.
One does not work with the other and you may want it to behave the same in both styles of BOM.
You can do it using OpenBOM flattened BOM. Check more in this article.
How to create Order BOM and Purchase Orders for Your Onshape Project - Bill of Materials (BOM) ... https://www.openbom.com/blog/how-to-create-order-bom-and-purchase-orders-for-your-onshape-project
