When will you update to the latest GD&T ASME Y14.5 standard?
Roy_Cross
Member Posts: 8 ✭
Your GD&T is out of date. The circle S symbol used to indicate that a datum feature reference applies at regardless of feature size (RFS) was discontinued in 1994. It was used in the 1982 standard. Since 1994 datum feature references defaulted to RFS per Rule #2. There was a 2009 revision and the latest version is 2018. Do you have plans to update your GD&T to at least the 2009 version?
