Is there an option to center dimension text by default?
hayden_morgan_nz
Member, User Group Leader Posts: 8 PRO
I have had a look around and a search but didn't seem to find anything.
If it doesn't exist, can we get the option of it in the settings.
Optionsphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381@hayden_morgan007
To be clear, the first time you insert the dim, it will automatically snap to center.
If you later move it, then that button can be used to re-center it.
Here is a video of the default centering as well as how to recenter.
Philip Thomas - Onshape5
If at any time after creation you have moved the dim and want to re center it, RMB over the dim and select 'edit' - there is a button that will re-center it.
I hope this helps
I know the button is there but have to do it for every dimension.
