Trying to create a Icosidodecahedron ( 60 triangle sphere)
paul_bartlett
Member Posts: 98 ✭✭
in General
I have solid a triangle 1" extruded depth and need to make the lower extruded face drafted at 8.95 deg and the side 2 extruded faces drafted at 13.22 deg. i am not sure how this is done. any help would be appreciated. The front view is the reference view.
https://cad.onshape.com/documents/2a58d84a32fa24a92fe052f7/w/915d6437d094bcab63b4b12f/e/4e8be17394278469a7e95776
Is this the shape you are trying to create?
https://en.wikipedia.org/wiki/Icosidodecahedron
Asking because googling the name seems to dig up a slightly different thing than you've described.
