How I can extrude this draving?
tommi_hölli
Member Posts: 2 EDU
Hi there,
I finished one model couple days ago and 3d printed it. I found that there was couple of faults and then try to fiks them by deleting about everything and then reshape rest of the parts. When I got everything ready, it noticed that sketch 1 cant be extruded anymore. Could someone help and tell me what is wrong with my model.
https://cad.onshape.com/documents/9e783480633f0f6bd03c3074/w/21b484e5e35331eb9fb4ab7c/e/c4e2284dcc02feedd2386be0
thanks
thanks
john_mcclary
Member, Developers Posts: 4,005 PRO
Your profile is not enclosed.
Check all your points to make sure they are coincident.
Quick way is to click the "Show Constraints" check box (1)
a quick scan of the sketch shows we are missing a coincident here (2)
Zoom in really close and you can see they are not touching
Make those coincident, and you will see everything turns gray, which means it is enclosed, and you can now extrude.
7
