Featurescript-Orient a plane
Hugh_Goodbody
Member Posts: 41 PRO
I would like to draw a rectangle on the end of an I beam. I have found the plane and the points for the sketched rectangle but the plane's axes are not parallel with the edges of the beam.
I have queried the beam edges, Is it possible to rotate the plane so that one of its axes is in the same direction as the queried lines?
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
say if your lines are in linesQuery, sketch plane is stored in planeQuery then:var skPlane = evPlane(context,{"face":planeQuery});skPlane.xAxis = evLine(context, {"edge":linesQuery}).direction;then skPlane should have xAxis aligned to one of the edges and you can transfrom 3d vertex coordinate vectors to 2d vectors in plane's coordinate system with worldToPlane() function
7
