Configure Derived Selection
  • Configure Derived Selection - This improvement will allow the user to configure the selections that are being derived.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    @cache_river_millworks This is not something we are considering now as the selection then builds a new id in the system and anything you would configure would probably cause a regeneration issue for downstream.  It might be best to have the parts already derived and control suppression.  It would require us to rebuild the derive feature to be a selection set.  I would need to understand the use case a bit better.
