Create a grip with grooves for fingers
in Drawings
Hi,
I've created a design of a grip (to be attached to my iPhone case and allow me to use it as a camera) and I would like to add grooves to the far end of the grip to provide a better ergonomic fit for my fingers - see image
The design is public and open
https://cad.onshape.com/documents/5409db07359d654534cafdbc/w/04c9b260591f6fb4bf87bc28/e/fcd38377ef341af3b7cfa2ff
You advise will be much apprecitated!
Moshe
Moshe
https://cad.onshape.com/documents/a6ece2cc65a81bb83a402f52/w/821f4ea6d868506e8c20a3ce/e/d890355b84e5aa33b4d2d733
It's actually easier to build each patch getting it right vs. working with a solid and contending with all the faces that a solid creates.
In the end, with a water tight manifold, you can just "enclosure" your volume.
Remember, there are no solids, just surfaces. Dropping down and using the primitives opens a whole new world when designing cool shapes.
