Offset chain with fillets
david_7david_7 Member, csevp Posts: 20 PRO
When offsetting a chain with fillets, have the fillets change to sharp corners if the offset fillet size is 0 or less.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    @david_7 Have you tried this?
