Derived parts with mate connectors...
So, I have been playing with Onshape and trying to figure out how I can use existing parts in a parts studio to possibly create a piping module with contextual relationships, etc.  I found the webinar on derived parts and thought it might be a promising solution to this problem.  Using 3DX certified pipe fittings, I added mate connectors on all of the possible connection points on the fitting.  I inserted the derived part into my parts studio, and used the transform by mate connector tool.... it works pretty good, with one exception, and it's kind of a big one. The only mate connector that follows the part with the transform is the one you use, (which might not be a huge deal, as I am able to add additional mate connectors to the derived part if I need to, however it leaves the others behind and you can't delete them without deleting the derived part.  If you transform the part in other ways first, all of the mate connectors are left behind.  A solution to this might be to only put one connector on the part, however with fittings like a tee or a reducer, you would want the option to pick one connection mate over the other.  Is this a glitch or am I doing something wrong?
  • C_D_RC_D_R Member Posts: 5 PRO
    was this addressed?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,948 image
    @C_D_R - yes, you have to select the part and all its mate connectors for them all to move together. This covers all instances - when you want them to move and when you want them to stay put.
  • Nathan_KadriaNathan_Kadria Member Posts: 6
    Is it possible to add a checkbox in the transform that includes the mate connectors in the transform that are "owned" by the parts that are selected?
    This would be very useful in this case where I'm only actually moving 3 parts, "Top Cover," "Frame," and "Prop Disks," but have to manually add all of the mate connectors that I use as references to the transform:
    I edited in the "Include owned mate connectors" checkbox.
