Feature Studio Keyboard Shortcuts
NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,891
For those of us who do a lot of custom feature coding, shortcuts can be very handy. Attached is a PDF of all the ones you didn't know existed! These will be added to the help documentation in the future.
    Nice, thanks.
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,060 ✭✭✭✭✭
    @NeilCooke
    Is there any way to disable the Alt-left and Alt-right shortcuts overriding the shortcuts to go back and forward in the browser?
    @MBartlett21 I don’t think that’s possible.
  • Sacha_FabienSacha_Fabien Member Posts: 3
    The shortcuts are only valid if your keyboard is set to ENG (US) on windows. If I want the same behavior as the ctrl-/ shortcut on a keyboard set to FRA (CAN) for exemple the shortcut becomes ctrl-é which took me a while to figure out.
    Good to know, thanks.
