What is the difference between "configuration" and "fullConfiguration" in assembly instances?
bentodjones
Member Posts: 1 EDU
in General
In the assembly api instance lists, an instance will look something like this:
- id: "Mp2bMzVAHb9uLFNST"
- name: "Part 1 <2>"
- partId: "JHD"
- isStandardContent: false
- configuration: "default"
- fullConfiguration: "default"
- type: "Part"
- suppressed: false
- documentId: "f7e4980117b6e6fe3d6cceb2"
- documentMicroversion: "231e582f0b55644b8295822b"
- elementId: "f898a89565ea6baaab0cb1c1"
What is the difference between "configuration" and "fullConfiguration"? If I am going to use this to call into the parts api, which one should I use as the configuration parameter?
Thanks!
