Circular pattern (feature) on a circular pattern instance - Regeneration time issue
clément_vannouque
                    Member Posts: 8 ✭
                                  in Drawings
                    Hello,
I'm working on this project : https://cad.onshape.com/documents/61c93af8be3c37adc571b378/w/5abe7de6e300b4377a5216d7/e/16a791dd3e86ebc7737ff12f
And I have an issue with regeneration time, it's starting to increase dramatically at the point I will not be able to work on it (more than 5min of regenaration).
I'm not sure what is taking so much calculation. Maybe I'm doing something wrong?
Looking at the regeneration summary, My circular patterns "led raw HX" are most of the time spent
Maybe it's because I'm using "faces" pattern instead of Feature? I didn't find any solution to use Feature for an instance of the previous circular pattern (looking at my file would be easier)
Can you help me out?
Thanks
Thanks
Even removing every feature patterns (I've read it's more expensive) doesn't change much
Instances outside the part
Knife edges
Sliver Edges
I am not saying this is perfect, but here is my solution
https://cad.onshape.com/documents/991c6f54ed1d6692a687fccf/w/1267e47cab3b0d2d24aa245d/e/d5746bbc21347c534a57713a
I hope this helps
Thanks for you reply!
I actually prefer (if not must) to treat every raw individually to be more flexible on their alignment!
I didn't know, it looks like you nailed it.
I was having issues at the 8th line with make sense since it was starting to "go off"
Thanks again everyone !
