Query for body created by opBoolean resolves to nothing.
Sacha_Fabien
Member Posts: 3 ✭
Hi,
I am trying to set the property of a part created by a opBoolean operation. The Boolean operation works well, but I can't find the body created afterward. The query resolves to nothing when passed into debug.
Here is a snippet of the code that I am trying to run:
var unitedBodyQueries = [qCreatedBy(id + "thickenEngravingFaces", EntityType.BODY), qCreatedBy(id + "thickenSeedFaceOffset", EntityType.BODY)];
var bodiesToBeMerged = qUnion(unitedBodyQueries);
opBoolean(context, id + "boolean1", {
"tools" : bodiesToBeMerged,
"operationType" : BooleanOperationType.UNION
debug(context, qCreatedBy(id + "boolean1", EntityType.BODY));
Here is the featurescript notice:
debug: Query resolves to nothing
I am running version 1174
Thank you!
Thank you!
NeilCooke
Moderator, Onshape Employees Posts: 5,915
Hi @Sacha_Fabien - a boolean union will take the id of the first body in the list, so query for id + "thickenEngravingFaces"
Senior Director, Technical Services, EMEA5
