Setting diameter or circle and length of line
mark_nahabedian
                    Member Posts: 31 ✭
                    I'm using the browser interface in Chrome of Ina Windows Surface laptop.
In a sketch, I'm trying to set the length of a line. I use the line tool to draw a line. When I then click on the length box to edit the length to the value of a variable, instead OnShape starts to draw another line.
I undo the new line, select the first line and click on the "length" display in the bottom right corner to edit it. If I then start typing the variable reference beginning with an octathorpe (sharpsign) the viewport changes. I can then type the expression defining the length of the line and hit return. When I do this though, rather than setting the length of my line, OnShape creates a new line parallel to the first at some distance from it.
I experience similar behavior when trying to set the diameter of a circle. Instead I get a new circle concentric to the first whose RADIUS is my specified amount greater than the original circle whose diameter I wanted to set.
I realize I can use the dimension tool to constrain the length of a line or the diameter of a circle, my my sketch gets very cluttered when I do that.
What should I be doing?
I still get the weird viewport behavior i(I wind up viewing from the edge Iof the sketch plain rather than normal to it) start the length with a sharpsign to refer to a variable, but I can work around that.
Is there a way to control whether dimensions are shown like one can for other constraints?
My sketch is not complicated: 6 circles, 8 lines. Take a look at "drill press depth stop mounting bracket" if you want to take a look. The sketch is cluttered because it's being drawn in an area of about 12 square inches: the remaining screen real estate on a Microsoft Surface laptop.
My sketch is complete. The part is a simple extrusion from the sketch except that there is a sort of recess in the middle that's not extruded to the same height as the rest, and I've not yet figured out how to do that. It was pretty easy to use the extrusion tool to select all of the regions for the first extrusion, and OnSgape did a really good job of figuring out what I wanted so I only needed to toggle a couple of regions in the extrusion. When I try to extrude the less high portion in the middle the relevant sketch lines aren't visible.
Thanks so much for your patience and help.
https://cad.onshape.com/documents/87c734434a3d09a1007f9322/w/822165c65a73fcefc6d8feb9/e/3af9931f54c596289d8aca98
I'm typing and nothing happens. https://imgur.com/KH96QBG
I am using a Chromebook btw.
