New finite element app - Beta testers wanted
jeremy_theler
Member, Developers Posts: 8 ✭
Hi all! I am preparing a new app for thermo-mechanical analysis using finite elements (a.k.a. simulation)
If someone is willing to be part of the testing team, please reply here so I can add you to the beta testing team.
Welcome aboard!
Brian
I intend to sign up for the alpha. Another question, I teach modeling and FEA. Will there be a free version for Onshape educational users?
Brian
So pricing for educational users will be paid if their project is private? There may a privacy risk in requiring students to make their projects public. It is possible some/many educational institutions will not allow instructors to force students to use public documents to do their assignments. Also, if each student has the same assignment, they can simply search for another student's public assignment, copy it, and submit it as their own work. I prefer that students keep their work private, thus keeping me from adopting applications that require public documents for students.
there is a "blue ball" at the location of maximum displacement and an "orange ball" where the max Von Mises stress is
you can switch them or on off, and if you take a screenshot they are there (or not)
ok, we might have to see this but we can match whatever policy Onshape implements regarding educational users
I feel that education should be based on sharing knowledge, very much like following the four freedoms of the FSF https://www.gnu.org/philosophy/free-sw.html and not doing the exact opposite.
In any case, CAEplex (as Onshape) keeps track of the changes using Git. It is currently not shown in the new version, but one can know if a project was cloned or created from scratch. See for example https://www.caeplex.com/project_history.php?id=9ef161f6175416712421c2ab5834ed51&step_next=1
My concern is more for requiring students to make their work public in order to do their required school work. In the use we have to meet FERPA requirements regarding student privacy. If a student is required to make their work public for an assignment and an instructor gives the student feedback within the document, then that feedback is public and not private, which likely violates the letter or spirit of the FERPA law. If a student willingly makes their work public without being coerced to do so by the instructor then there isn't a FERPA issue if the student is aware that any comments made by the instructor may also become public. For most students, public documents is likely not an issue. But what about those one or two students per semester that explicitly do not want to make their work public? I cannot coerce them into doing so, therefore I cannot have them do an assignment that requires public documents unless they pay for it, which causes another problem.
I hope you find a way for educational users to use private documents for analysis, even if there is a limit to the number of them.
I poked around your website a bit last night and am impressed by what you have so far. This may be the first web-based Finite Element Approximation app available to Onshape that I have liked.
Brian
You are already on the testing team. Just make sure you are logged in into Onshape, open the App Store, find "CAEplex" under "simulation" (a term I do not fully agree with) and subscribe to the app. Then open one document and add the CAEplex app to start a FEM case (mechanical for now).
Thank you for your compliments.
Can we use custom materials?
i am interest in using the app to do remeshes of the onshape models, is it possible to do it? i am using the models for simulations too but in my case is CFD, with openfoam, and i am having issues with the finer meshes, is it possible to remesh the model, and export the mesh? (also if we can export separatly the different surfaces of the same model, like cut it in surfaces but that when re assambled it is still watertight (still share the same vertices between each separate exported surface)
thanks!
