Double pinion Planetary gears.
chand_basha
Member Posts: 63 EDU
in General
Hi all,
I am facing a small problem in the assembly of a Double pinion planetary gear system. Planetary gears are interfering with sun gear.
Any help would be appreciated.
Thank you
link to my document: https://cad.onshape.com/documents/c8eb0994416574a18b8c7fd9/w/4b77e533796f0e5b0bb8d496/e/1e4bab8f86d4ff017342712f
Thank you
https://cad.onshape.com/documents/e1a2e568af31c4f0e97248fe/w/3fa511e62ccb433df4dfc8ff/e/daa52a709920424f5f6dd289
https://cad.onshape.com/documents/5742c8cde4b06c68b362d748/w/b493e0cb681bbf9497d9f4b3/e/c72760543a0d4412e72f6d38
I genuinely tried lot of times by modifying gear ratios. Eventually, I was not getting proper meshing.
The mistake I did is, I have created a Revolute mate of a Sun gear with one edge of a Ring gear, that I shouldn't have done.
By looking at your assembly I get to know this mistake.
Thanks again for helping me
