Strange behavior of Beam FeatureScript
After saving and logging in again I had these errors.
It is no longer possible to create Beams in this drawing.
No other drawings/part studios are affected.
Thanks for your help
Frank
Frank
NeilCooke Moderator, Onshape Employees Posts: 5,905
@frank_ring - I just opened your doc and it seems to have "fixed itself"?
Senior Director, Technical Services, EMEA5
Never had this behavior before - thanks for your help!
You do not seem to be using the official beams FS.
It is here: https://cad.onshape.com/documents/e15c2c668d138f01242d0c80
The document that you are using seems to be a copy that has since been trashed, which is why this may be happening. The document that you are using is: https://cad.onshape.com/documents/f97fc439bc2cfd0b1627cdb8, and it says that it is in the trash when you try to open it.
