loft twist even with vertex matching
I have matched the vertex counts of the end faces and matched two vertices, but the loft is still twisted. The twist is most obvious in the bottom view).
https://cad.onshape.com/documents/70d966de3badcd4297a0364f/w/f881c41642a17ab1e8adf1a4/e/6f0b58722b7a9ad808859279
What did I do wrong? I reviewed several loft-twist questions posted previously in this forum, and double-checked the conditions that helped those users, but I must be missing something different from them.
Is there a better way to construct this kind of part?
  • jim_wilson436jim_wilson436 Member Posts: 23 PRO
    Thank you, Neil and Steve!
    Neil's solution hit at the crux of my error -- I didn't realize the matching vertices needed to be segment endpoints, but that does make sense. Also, thank you for introducing the shell feature. I was unaware of that tool, and it will surely be quite useful in the future as well.
    Also, kudos to Steve for an alternative approach to making the part.
    Cheers!
    Jim
    Uh, that was dumb of me. How do I get rid of "Accepted answer" on my own post. LOL
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,003 image
    That's fine - it was a great answer!
